18-Opal
May 23, 2024 8:50 AM UTC
Creo worker is publishing Integer 1 as I
Any settings to publish as 1
TDTAnswer
18-Opal
Jun 5, 2024 5:35 AM UTC
Hi Everyone,
Thanks for the inputs.
We had missed some of the custom font config files to deploy in worker machine.
After placing the required files, the worker is publishing as expected.
May 23, 2024 9:11 AM UTC
Do you mean for Creo drawing annotation "1" will be published as a "I"?
TDT18-OpalAuthor
18-Opal
May 23, 2024 9:41 AM UTC
@Hemant_Chaugule Yes
May 23, 2024 10:25 AM UTC
Then may be you can try changing below recipe file setting :
Advanced > PDF Output Setup > Font Control > Stroke Non trueType Font.
If this doesn't work, you can manually export the file from Creo to check the output and if output is good then use same value to the above recipe file,.
joe_morton
May 24, 2024 6:57 PM UTC
Does the Creo worker have the required fonts loaded?
TDT18-OpalAuthor
18-Opal
May 27, 2024 6:46 AM UTC
Hi @joe_morton,
Is it possible to load fonts in Creo workers?
joe_morton
May 28, 2024 3:49 PM UTC
This looks like what you need: https://www.ptc.com/en/support/article/CS32299?source=search
What I mean by my comment is that it would be possible to set a default font in C:\Windows\fonts that may not exist on the CAD Worker, since it might be a different computer. So I'd recommend checking what you have set in your drawing options for default_annotation_font, update it if required, and make sure that whatever font you select is present on the CAD worker as well.
May 27, 2024 3:32 PM UTC
Did you applied the same Creo configuration used on the CAD workstation within the CAD worker startup dir (proeworker)?
Emeritus
May 30, 2024 9:53 AM UTC
Hello @TDT,
It looks like you have some responses from some community members. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Community Moderation Team.
