Inseparable assembly
Hi
I have the requirement in a Java api program to check if an assembly is set inseparable in Creo. Does anyone know what property or method this is ?
Hi
I do not have that enabled but I do see an "Assembly type" on the WTPart that calls out "Inseparable". If not directly captured in the EPMDocument, you can find it by the assiciated WTPart I would assume. Haven't played with this much.
No account yet? Create an account
Enter your E-mail address. We'll send you an e-mail with instructions to reset your password.
