Dec 10, 2025 8:26 AM UTC
NX设置引用集后可视化不正确
I am using Windchill PDMLink Release 12.1 and Datecode with CPS 12.1.1.2
NX中组件下面有个子件,对子件右键--替换引用集--Empty,如此就只会显示子件,如图1
如果子件右键--替换引用集--BODY,就会全部显示,如图2
如果按照这种方式(子件右键--替换引用集--Empty)去操作后,检入windchill后生成的可视化却会将之前隐藏的那个引用的底盘又显示出来。如图三。
我们测试了,用可视化服务器上的NX打开的话看到的结果是正确的(也就是只会显示那个子件)
是需要设置哪里?
2R2445162
Dec 10, 2025 8:27 AM UTC
所涉及到的截图如附件,期待专家的支持
Emeritus
Dec 16, 2025 11:06 AM UTC
Hi @BL_9537051,
Thank you for your question.
Your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best Regards,
Vivek N
Community Moderation Team
joe_morton
Dec 16, 2025 3:23 PM UTC
I'm not familiar with NX, but I know that with Creo, the Visualization settings default to publishing the master rep - with everything visible. Is this a similar setting in NX, where there is a "master" view where everything is shown?
