Using Flexibility
  • June 18, 2025
  • 2 replies
  • 325 views
I am using Windchill PDMLink Release 11.2 and Datecode with CPS 11.2.1.12
On one set of Creo is mounted another set with flexibility to use variants (2 options).
When we check-in in Windchill using a variant it archives the 2 options duplicating the Assembly.
How can we make it archive the chosen flexibility option without duplicating the assembly?
    Have you looked at this
    Visualization > Dynamic Structure > Display representations from image associated EPM documents to Yes
    Community Moderator
    June 25, 2025
    Hello @ajuanjo,
    You have a response from a community member. If it helped you solve your question please mark the reply as the Accepted Solution.
    Vivek N.
    Community Moderation Team.
