18-Opal
Jun 14, 2024 7:33 AM UTC
WTPart Visualization
I have a Top level WTPart Structure associated with Creo CAD Assembly through Owner link.
I have some of the standard parts used in WTPart Structure.
The Standard parts have a owner link with non-creo CAD Application and Image link with Creo CAD.
The Problem comes here, As i have used standard parts in top level WTPart Assembly the WTPart Visualization shows non-creo CAD visualization as it has owner link.
How to overcome this problem?
I dont want to change the link for standard parts.
vdegaonkar
Jun 17, 2024 8:13 AM UTC
You need to enable preferences to visualize Imagelink association or Assembly Feature / Flexible Position affected components.
For Image link associated object visualization refer - Visualization of Image-Associated and Contributing Image-Associated Parts in Dynamic Part Structure (ptc.com)
If you are MPMLink and visualize BoMs in MPM (ex  BoM Transformer, process plan etc) then you may need to add few additional WVS Properties and republish representations
Emeritus
Jun 21, 2024 8:53 AM UTC
Hello @TDT,
It looks like you have a response from a community member. If it helped you solve your question please mark the reply as the Accepted Solution.
Community Moderation Team.
