11-Garnet
September 19, 2023
filename renaming issue
  • September 19, 2023
  • 2638 views
As per this topic:
this is what i'm getting
kindly suggest on this.
HelesicPetr
Hi @Boopathy
What do you want to suggest?
Please describe your issue clearly and provide some log file to see what's going on in the background process
I can just see that rename operation has been done, that's all.
PetrH
Boopathy11-GarnetAuthor
11-Garnet
September 19, 2023
hi Helesic,
rename is not happening i got only this print alert.
HelesicPetr
@Boopathy
You need to open method server log and check what is there in the log file.
folder on the server where WCH is installed ..../Windchill/logs MethodServerxxxx.log
PS> the link to original post is wrong. This one is correct > Windchill-Custom-Utility-Examples/
PetrH
