Windchill PDM Link 11.1 (M020)
  • June 5, 2024
  • 3 replies
  • 1026 views
I am using Windchill PDMLink Release 11.1 and Datecode with CPS M020
I tried to download Windchill PDM Link 11.1 (M020) Version, but I cannot find the version on the download page.
Translated a portion from the body of this post from Korean to English using google translate
Body - Windchill PDM Link 11.1 (M020) Version을 다운로드 받으려하였는데 다운로드 페이지에서 해당 버전을 찾을 수 없습니다.
- By Community Moderation Team
Community Moderator
June 10, 2024
Hi YJ_9923893,
Thank you for your question.
Your question appears to be well documented, however I'd like to recommend to bring more details and context to your initial inquiry.
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Community Moderation Team.
1: Warning, Windchill 11.1 is an old version
2: You may need to download the CPS separately.  First, download a Windchill version older than that CPS, and install it. Then download the CPS version that you want and use it to update the installed Windchill.
HelesicPetr
Hi @YJ_9923893
Or open a TS Case and PTC can provide you the download media
PetrH
Community Moderator
June 14, 2024
Hello @YJ_9923893
It looks like you have some responses from some community members. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
