windchill+ ui
  • May 13, 2025
  • 2 replies
  • 660 views
I am using Windchill PDMLink Release N/A and Datecode with CPS N/A
windchill+ 는 ui가 jsp로 되어있나요? 아니면 react나 다른 프레임워크로 되어있나요 ?
궁금하네요 . 그리고 파트너사에서 react나 vue.js로 화면을 따로 구성하여 서버와 연동하여 사용할수도 있는지 궁금합니다.
    Best answer by avillanueva
    I saw this slide at the conference but caveat that this is futures and should be taken with grain of salt:
    avillanueva
    23-Emerald I
    23-Emerald I
    May 14, 2025
    Community Manager
    May 20, 2025
    Hello @SW_13138537
    It looks like you have a response from a community champion. If it helped you solve your question please mark the reply as the Accepted Solution.
    Vivek N.
    Community Moderation Team.
