About an IoT application
- March 17, 2016
- 3 replies
- 8585 views
Hello Everyone here
I have developed an Energy meter to by using
1. 8-bit PIC16F887 Microcontroller
2. TI CC2520 as a zigbee module
3. TI CC 2592 as it range extender
in this i measure current , voltage , power- active and reactive , power factor as the parameters essential billing parameters
now we want to develop an IoT for this application in this regards i want to known:-
1. This Micro controller has a 256 bytes of EEPROM memory where we have just stored these parameter values , which file format thingworx support to transfer our real time data .
2.Is it possible that once we communicate our parameters using Zigbee to a PC and then convert it to the file format which thingWorx can support ?
3.Which communication protocol thingworx support to transfer the data either : Wifi , Bluetooth , Ethernet.
4.For zigbee if we require an gateway then how can we develop it and which communication standard should it support
i have also attached here a slides about the application idea
