Access denied when saving image to a Repository
  • October 2, 2015
  • 985 views
Hello again friends
When I try and save an image to a repository using the standard SaveImage service, I am getting the following non-descriptive error: Unable to Invoke Service SaveImage on Hails_GEIP.ChatMessage.Repository : \ThingworxStorage\repository\Hails_GEIP.ChatMessage.Repository\212410109 (Access is denied)
Could someone please help me understand why? Or if you have seen this before, how did you get around it?
Thanks in advance!!
    Alex, when you executed the SaveImage service, did you add the name of the image file in the path too? You would normally get access denied error if you just have '/' in the path. Try adding the name of the image too, for example '/test.jpg'.
