11-Garnet
Add entry to stream
hi, i have a thing with several service each of them add a entry to stream when is executed, the process for add this entry is same on all services but not all services add entry, and i don´t know which is a problem. can you help me?
  • At what frequency all the services executed?
  • Ensure each services writing data with unique timestamp... else it will be overwrites the data.
Here some articles:
Here some articles:
11-Garnet
I think the timestamp was the problem, after testing and adding a delay in the service when adding the log the problem did not occur. Thanks!
