AddPropertyDefinition on Thingworx display: Must Specify A Property Name
Hi, i have an issue adding dynamically properties to a remote template create by snippet.
I get an error reporting this:
JavaException: com.thingworx.common.exceptions.InvalidRequestException: Must Specify A Property Name
this is the code:
//template creation
var paramsRemoteThing = {
description: "This is the description", // STRING
thingTemplateName: 'RemoteThing',
tags: 'MyParent:Template'
Resources["EntityServices"].CreateThingTemplate(paramsRemoteThing);
//add a remote property
var paramsIns = {
defaultValue: undefined , // STRING
description: undefined , // STRING
readOnly: false, // BOOLEAN
type: "STRING", // BASETYPENAME
remote: false , // BOOLEAN
remotePropertyName: "ThisIsMyNamedProperty" , // STRING
timeout: undefined , // INTEGER
pushType: "VALUE" , // STRING
dataChangeThreshold: undefined, // NUMBER
logged: false, // BOOLEAN
name: "variabile" , // STRING
pushThreshold: undefined , // NUMBER
dataChangeType: "VALUE" , // STRING
category: "remote" , // STRING
persistent: true, // BOOLEAN
dataShape: undefined // DATASHAPENAME
// try to add property
try{
ThingTemplates[nomeTemplate].AddPropertyDefinition(paramsIns );
}catch(e){
logger.error("ERROR adding proeprty: "+e)
What am i missing ? after creating is necessary to bind remote property?
