Application error - Error Handling Publish Arrived for [property] : [null]
  • November 30, 2017
  • 1861 views
I am receiving error in publishing data from MQTT to Thingworx Foundation server. "Error Handling Publish Arrived for [property] : [null]"
I can see the values coming in the property every time I refresh it but  it is not saving it in Valustream and keep giving me this error in Application Log.
Initially, I thought the error probably be because the data coming in is in String format and my property type is Integer but even after making required changes I am still getting this error.
I wrote my MQTT scripts which runs a loop and keep sending the data to my MQTT broker.
Neetu
Hi Neetu,
Are you still having this issue? Could you please share screenshots from all the bindings and how you are logging the values to the Value Stream?
