Authentication issues with appKey in HTTP session, alternating
  • October 9, 2014
  • 4 replies
  • 3652 views
not sure if this is a known issue or even an issue at all, but I observe the following behavior when working in a HTTP session when using an appKey only, e.g. when accessing the REST API and not logging in.
E.g. open a Chrome incognito window. Paste in a URL with an appKey
The first time this call returns the desired result. The second time (hit Ctrl-R or refresh), I get an error page:
"HTTP Status 401 - No authType or appKey parameter has been specified for Authentication Scheme: AUTH_THINGWORX_APPKEY"
Another Ctrl-R refresh brings back the normal call result and the next one again the error. It alternates.
The same alternating errors occur from within my http client library that I use to access the REST API when I use sessions. This basically requires that I cannot use the session capability and must create a new request every single call. Also happens in a normal browser window when not doing password authentication.
After password authentication with ThingWorks, it works fine in normal browser windows.
Is this intended or an issue?
Thanks!
Hi Dwight,
Do you also use the x-thingworx-session=true in the url?
I had this behaviour when not using this url parameter set to true.
BR,
Vladimir
dwightwhe1-VisitorAuthor
Thanks Vladimir,
this solves it.
Best
