pshashipreetham
Best Way to get Alerts/Events on the Tags Quality
I want to get Alerts or configure events based on the Tag Quality(Kepware Tag Quality). What will be the best way to do it?
@c_lowy can you help me out on this ?
Shashi
abjainAnswer
@pshashipreetham Usually if the property has not been updated even once, then it will show this default time value for last updated. Please check for a property if it has been updated even once. Also are these properties marked as 'Logged' and 'persistent'?
pshashipreetham
Hi @abjain
I have checked the blog before I posted mine, how can we check if the kepware is connected or not !!
Shashi
Shashi Preetham || +91 8099838801 || shashi@psptechhub.com
@pshashipreetham On the industrial connection thing which is connected to Kepware, you can check the isConnected property. If its true than Kepware is connected. You can write a subscription to the property.
