Binding Widget
Hello ,
I'm currently having an issue with a widget i am creating , everything is set in place in javascript , the widget can take information from the widget with no properties with no problem but when it comes to binding information onto the widget it doesn't seem to work for some reason , it seems that updateProperty function doesn't run at all .
here's part of my code :
RUNTIME :
this.updateProperty = function (updatePropertyInfo) {
console.log("ListCheckBox : updateProperty executes");
if(updatePropertyInfo.TargetProperty === 'DATA') {
var singleProperty = updatePropertyInfo.SinglePropertyValue;
this.setProperty('DATA', singleProperty);
this.afterRender();
if(updatePropertyInfo.TargetProperty === 'RESULT_DATA') {
this.setProperty('RESULT_DATA', singleProperty);
this.afterRender();
IDE :
this.afterSetProperty = function (name, value) {
var refreshHtml = false;
switch (name) {
case 'DATA':
refreshHtml = true;
break;
case 'RESULT_DATA' :
refreshHtml = true;
break;
default:
refreshHtml = true;
break;
return refreshHtml;
this.afterAddBindingSource = function (bindingInfo) {
if (bindingInfo.targetProperty == 'DATA') {
this.updatedProperties();
if (bindingInfo.targetProperty == 'RESULT_DATA') {
All the functions in the runtime run normally , renderHTML() , afterRender() ... but UpdateProprety doesn't run at all , the console.log I put there doesn't show up.
