C SDK connection does not work
I cannot get my Raspberry Pi 3 to connect to the Thingworx server. I have searched through the boards, tried disabling SSL authentication, upgraded my software, etc. but I always try to get the same error after trying to run the ExampleClient provided in the examples.
[FORCE] 2017-07-11 13:33:45,456: Starting up
[ERROR] 2017-07-11 13:33:45,457: twStream_CreateFromFile: error opening file: /opt/thingworx/subscribed_properties.bin
[ERROR] 2017-07-11 13:33:45,457: subscribedPropsMgr_Initialize: Error opening: /opt/thingworx/subscribed_properties.bin
[ERROR] 2017-07-11 13:33:45,713: Error intializing SSL connection
[ERROR] 2017-07-11 13:33:45,713: twWs_Connect: Error restarting socket. Error 13
[ERROR] 2017-07-11 13:33:50,967: Error intializing SSL connection
[ERROR] 2017-07-11 13:33:50,967: twWs_Connect: Error restarting socket. Error 32
[ERROR] 2017-07-11 13:33:56,221: Error intializing SSL connection
[ERROR] 2017-07-11 13:33:56,221: twWs_Connect: Error restarting socket. Error 32
[ERROR] 2017-07-11 13:34:01,222: twApi_Connect: Max number of connect retries: 3, has been reached
[ERROR] 2017-07-11 13:34:01,222: main: Server connection failed after 3 attempts. Error Code: 1001
What could be the problem? Thank you for your help in advance.
