C# SteamSensorClient Sample Test Error  (Code 1001)?
  • April 8, 2015
  • 1225 views
I do not know why the connection error
Make sure that any problems with the following code:
var config = new ClientConfigurator();
            // The uri for connecting to Thingworx
            config.Uri = "[http://10.10.10.110/Thingworx | http://10.10.10.110/Thingworx]";
            // Reconnect every 15 seconds if a disconnect occurs or if initial connection cannot be made
            config.ReconnectInterval = 1;
           // Credentials Example
            SecurityClaims claims = new SecurityClaims();
            claims.addClaim(RESTAPIConstants.PARAM_APPKEY, "df7cd577-39f1-48c3-a00d-81e1ad22c14d");
           // claims.addClaim(RESTAPIConstants.PARAM_USERID, "frontis02");
           // claims.addClaim(RESTAPIConstants.PARAM_PASSWORD, "frontis02");
            // Set the security using an Application Key
            var appKey = "df7cd577-39f1-48c3-a00d-81e1ad22c14d";
           // var claims = SecurityClaims.fromAppKey(appKey);
            config.Claims = claims;
            // Set the name of the client
            config.Name = "SteamSensorGateway";
            // Get the scan rate (milliseconds) that is specific to this example
            // The example will execute the processScanRequest of the VirtualThing
            // based on this scan rate
            int scanRate = Int32.Parse("1");
            // Create the client passing in the configuration from above
            SteamSensorClient client = new SteamSensorClient(config);
            try
                // Create two Virtual Things
                SteamThing sensor1 = new SteamThing("Temperature", "1st Floor Steam Sensor", "Temperature", client);
                SteamThing sensor2 = new SteamThing("Humidity", "2nd Floor Steam Sensor", "Humidity", client);
                // Bind the Virtual Things
                client.bindThing(sensor1);
                client.bindThing(sensor2);
                // client.connect();
                // Start the client
                client.start();
            catch (Exception eStart)
                Console.WriteLine("Initial Start Failed : " + eStart.Message);
com.thingworx.common.exceptions.TwApiException
  _HResult=-2146233088
  _message=Error opening connecting to Platform. There was an error initializing the Socket. (Code 1001)
  HResult=-2146233088
  IsTransient=false
  Message=Error opening connecting to Platform. There was an error initializing the Socket. (Code 1001)
  Source=thingworx-dotnet-common
  Code=1001
    Hi Hyunkoo,
    Is your platform configured to use SSL? When using the newer SDKs, this error is usually attributed to non-SSL connections.
