Can I log write subscription based on data change of property of another thing?
I have two things contains same properties, want to call the a subscription on data change of those things properties.
If we write subscription inside things we can call respective on data change event which is fine. But we are looking common subscription which execute on data change of all things.
Is it possible to write common subscription, pass thing name dynamically to it at run time and check on data change property of that ?
Anil Kesana
