Can template inheritance be changed?
All,
is it possible to change the Base Thing Template of an existing template?
A customer has decided to split an existing template into two new templates and divide up the properties and services between the two. All existing things are based on one of these to we should be able to keep the based on the old template as long as we can change the Base Thing Template of the old template to reference one of the new ones.
Is this possible to do?
Best regards
Daniel Södling
