Changing a user password in a service
  • August 12, 2014
  • 4 replies
  • 2646 views
Can I change a user's password from a service?
I have tried this.
var newPassword="pickles"
var params = {
data: newPassword
// result: STRING
var encryptedPassword = Resources["EncryptionServices"].Encrypt({
data: newPassword
Users["testuser1"].password=encryptedPassword
But the property password does not exist.
    Hi Bill,
    If you go to entities and find the user you would like to set the password for, there is a code snippet named, ChangePassword, that can be used to change the password of a user that already has a password assigned. It requests the current password before allowing you to change it as a security measure. This is the one you would typically use. Alternatively, there is also the service, AssignNewPassword, which doesn't require the old password before assigning a new one. This would be useful in fewer cases and would most likely be used for administrative purposes if a password was forgotten.
    Saeed
    Hello Saeed,
    Why can't i find ChangePassword  or AssignNewPassword snippet?
    Alex
    They are both part of the User object.
    So if you go to the Entities tab and find a user, in the Services you'll find these two.
