Check if user is enabled
  • August 14, 2014
  • 2 replies
  • 1152 views
I want to return a list of users, however I do not want to include the ones that are not enabled. How can I differentiate them?
Thank you,
Mike
    Hi Michael,
    Unfortunately, there isn't an easy way to generate a list of only enabled
    Users
    . I've requested a couple
    Services
     from development that will
    make this much easier. For the time being, you'll need to get all of the
    Users
    , iterate through the resulting
    InfoTable
     and use a REST call to get the
    User
     as JSON. Of course, then you'll need to parse through the JSON to find the value for "enabled". If the value is true, you'll add it to another
    InfoTable
     that you will return (or alternately, if it's false, you could remove disabled
    Users
     from your initial
    InfoTable
    Here's the code:
    var users = Groups["Users"].GetGroupMembers(); // Get All Users
    var numberOfUsers = users.RowCount();
    var headers = new Object();
    headers.Accept = "application/json";
    var i = 0;
    while (i < numberOfUsers) {
      var user = Resources["ContentLoaderFunctions"].GetJSON({
        headers: headers,
        url: "http://localhost/Thingworx/Users/" + users.name,
        username: "Administrator",
        password: "admin",
        ignoreSSLErrors: true,
        withCookies: true,
        timeout: 30
      if (user.enabled == "false") {
        users.RemoveRow(i); // Remove Disabled User
        numberOfUsers--; // Decrement Number of Users
      } else {
        i++; // No Users Removed
    result = users; // Return Final InfoTable
    Thank you Adam! That was a huge help!
