Checkbox changed event to fire navigate service
  • March 2, 2014
  • 3 replies
  • 1318 views
I have a service set up in a mashup that returns a true or false value. I have that result tied to a checkbox widget. I have the checkbox changed event tied to a navigation widget navigate service. When the original service in the mashup runs, it changes the checkbox value from a default of false to true, however the navigation widget does not initiate its navigate service. If I manually click the checkbox, the navigation widgets navigate service will fire.
Any help would be appreciated.
    Hi Michael, what you can do is to use the Service Invoke Completed to fire the Navigation Widget as well.
    If it should only fire on a True or False from the Service, then you can wire it through a Validation Widget.
    Pai,
    Thank you for the quick response. Is there a way I can have the expression field for the validator check the value of a returned selected row from a service and if it equals a certain value, return true? Not sure exactly how I could reference service results within the expression field of the validator.
    Pai,
    Thanks for the direction.
    I was able to figure it out. Added the parameter for the true/false value from the service to be brought into the validator. Then simply set the validator expression to "Output = Navigate_Boolean" and have the true event set to the navigation widgets navigate event.
