Choosing the most appropriate data storage method
Hello all,
I'm implementing alarm handling mechanism which should closely resemble that of alerts (Alert History). However, I stumbled upon a problem associated with a stream. Say I have an array of certain entries which I have to put into a stream. If I loop through that list and run "AddStreamEntry" service with each iteration, in the end I'll see only a single (last) entry. I found an explanation to this in ThingWorx documentation - if a new record has the same timestamp as that of the previous (within 1ms) , the previous entry will be overwritten.
| The timestamp is a key field for streams. If you add an entry with the same timestamp, it will overwrite the previous timestamp (upsert). To avoid overwriting, specify milliseconds for the timestamp. |
Does it mean that if two alerts will get acknowledged within 1 ms only 1 record will be made in AlertHistory stream?
