communication between mashup and master
  • May 9, 2016
  • 5 replies
  • 2248 views
I have a master that contains a grid, slider and dropdown.   I have a mashup that consists of a bar graph.  I can click on individual bars and have the graph drill down to another level (retrieves new data and shows another bar graph).  So the level number ranges from 1 to x.  Upon this action (clicking on a bar) I need the slider and dropdown to update to what the current drill down level is.  On the flip side when the user selects a new value from the dropdown or the slider I need the graph to update itself to that selected level.    The problem I am having is I do not know how to implement this without using session variables and getting myself stuck into an infinite loop (by using the change event on a session variable).
-Ken
    Ken, have you tried using Contained Mashups and Mashup parameters? You can bind your output to a Mashup Parameter in the Contained Mashup (that has your bar chart) and then bind that Mashup Parameter back into your primary Mashup (that has the grid, slider and dropdown).
    kyetzer1-VisitorAuthor
    Aanjan,
         Thanks for the Info I will give it a shot.
    -Ken
    Aanjan,
           Just out of curiosity is there any way to easily duplicate all the logic in a master and place it into a regular mashup (i.e., duplicate a master but save it as a regular mashup)?
    -Ken
