Connect SQL DB to Thingworx
  • October 3, 2017
  • 3961 views
I would like to know whether Thingworx can fulfil the following:
1- Is it possible to integrate an SQL database as a structured DB for our Thingworx implementation?
2- Is it possible to create our own SQL database structure, and make Thingworx use it accordingly?
3- Can we create our own HTML web forms and integrate them with Thingworx ?
4- Can we build our own APIs to push and pull from our SQL database (supposedly) serving as a structured DB for our Thingworx instance?
5- Can we build our own reports (dashboards, Listing, Live reports) and use your functions and controls to inject them with data?
6- Can we create our own controls and functions?
Thank you!
  • Yes, either via using the SQL database as the persistence provider for Thingworx (i.e. Postgres or MSSQL Server), by using the JDBC connector extension (for any database with a JDBC driver) from the marketplace (ThingWorx IoT Marketplace) or by exposing an API layer on top of the database.
  • Yes, see above; in this case you would use the JDBC driver approach
  •      Yes, you can use the underlying REST APIs exposed by Thingworx in custom HTML web forms
4- Can we build our own APIs to push and pull from our SQL database (supposedly) serving as a structured DB for our Thingworxinstance?
  • Yes, this actually happens automatically as you create web services to query (or write commands) to your SQL database via the JDBC driver approach -- every query or command exposes a RESTful endpoint that you can then use. You could also write a custom API layer on top of your database and Thingworx could interact with that API.
  • I'm not sure I see the difference between this and the HTML web form question? Could you clarify?
  • Yes
