Connection to Git repository using on-prem GitLab fails due to SSL error
We are trying to use the Git Backup extension 2.0.2 on ThingWorx 8.4.1 with GitLab community edition hosted on-premises. When trying to push to the repository this fails with an error message (server FQDN has been modified):
Push Error: org.eclipse.jgit.api.errors.TransportException: https://enterhostname.customer.local/iot/thingworx-test.git: Secure connection to https://enterhostname.customer.local/iot/thingworx-test.git could not be stablished because of SSL problems at org.eclipse.jgit.api.PushCommand.call(PushCommand.java:180) at gb.GitBackupTemplate.Push(GitBackupTemplate.java:156) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.lang.reflect.Method.invoke(Unknown Source) at com.thingworx.common.processors.ReflectionProcessor.processService(ReflectionProcessor.java:261) at com.thingworx.handlers.ReflectionServiceHandler.processService(ReflectionServiceHandler.java:50) at com.thingworx.handlers.ServiceHandlerBase.processServiceWithMetrics(ServiceHandlerBase.java:48) at com.thingworx.things.Thing.processServiceRequestDirect(Thing.java:8306) at com.thingworx.things.Thing.processAPIServiceRequest(Thing.java:8244) at com.thingworx.webservices.BaseService.handleInvoke(BaseService.java:3228) at com.thingworx.webservices.BaseService.service(BaseService.java:499) at javax.servlet.http.HttpServlet.service(HttpServlet.java:741) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:231) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166) at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:53) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166) at com.thingworx.security.contenttype.ContentTypeFilter.doFilter(ContentTypeFilter.java:138) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166) at com.thingworx.security.filter.ValidationFilter.doFilter(ValidationFilter.java:22) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166) at com.thingworx.security.authentication.AuthenticationFilter.propagateRequest(AuthenticationFilter.java:541) at com.thingworx.security.authentication.AuthenticationFilter.doFilter(AuthenticationFilter.java:210) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166) at org.tuckey.web.filters.urlrewrite.RuleChain.handleRewrite(RuleChain.java:176) at org.tuckey.web.filters.urlrewrite.RuleChain.doRules(RuleChain.java:145) at org.tuckey.web.filters.urlrewrite.UrlRewriter.processRequest(UrlRewriter.java:92) at org.tuckey.web.filters.urlrewrite.UrlRewriteFilter.doFilter(UrlRewriteFilter.java:389) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166) at com.thingworx.security.filter.ClickjackFilter.doFilter(ClickjackFilter.java:207) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166) at com.thingworx.security.filter.ProhibitIfNotLeaderFilter.doFilter(ProhibitIfNotLeaderFilter.java:120) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166) at com.thingworx.security.filter.HttpResponseHeadersFilter.doFilter(HttpResponseHeadersFilter.java:173) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166) at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:202) at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:96) at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:526) at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:139) at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:92) at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:678) at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:74) at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:343) at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:408) at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:66) at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:860) at org.apache.tomcat.util.net.Nio2Endpoint$SocketProcessor.doRun(Nio2Endpoint.java:1676) at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49) at org.apache.tomcat.util.net.AbstractEndpoint.processSocket(AbstractEndpoint.java:1087) at org.apache.tomcat.util.net.Nio2Endpoint$Nio2SocketWrapper$2.completed(Nio2Endpoint.java:589) at org.apache.tomcat.util.net.Nio2Endpoint$Nio2SocketWrapper$2.completed(Nio2Endpoint.java:567) at org.apache.tomcat.util.net.SecureNio2Channel$1.completed(SecureNio2Channel.java:968) at org.apache.tomcat.util.net.SecureNio2Channel$1.completed(SecureNio2Channel.java:897) at sun.nio.ch.Invoker.invokeUnchecked(Unknown Source) at sun.nio.ch.Invoker$2.run(Unknown Source) at sun.nio.ch.AsynchronousChannelGroupImpl$1.run(Unknown Source) at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61) at java.lang.Thread.run(Unknown Source) Caused by: org.eclipse.jgit.errors.TransportException: https://enterhostname.customer.local/iot/thingworx-test.git: Secure connection to https://enterhostname.customer.local/iot/thingworx-test.git could not be stablished because of SSL problems at org.eclipse.jgit.transport.TransportHttp.handleSslFailure(TransportHttp.java:619) at org.eclipse.jgit.transport.TransportHttp.connect(TransportHttp.java:569) at org.eclipse.jgit.transport.TransportHttp.openPush(TransportHttp.java:435) at org.eclipse.jgit.transport.PushProcess.execute(PushProcess.java:160) at org.eclipse.jgit.transport.Transport.push(Transport.java:1310) at org.eclipse.jgit.api.PushCommand.call(PushCommand.java:169) ... 68 more Caused by: javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at sun.security.ssl.Alerts.getSSLException(Unknown Source) at sun.security.ssl.SSLSocketImpl.fatal(Unknown Source) at sun.security.ssl.Handshaker.fatalSE(Unknown Source) at sun.security.ssl.Handshaker.fatalSE(Unknown Source) at sun.security.ssl.ClientHandshaker.serverCertificate(Unknown Source) at sun.security.ssl.ClientHandshaker.processMessage(Unknown Source) at sun.security.ssl.Handshaker.processLoop(Unknown Source) at sun.security.ssl.Handshaker.process_record(Unknown Source) at sun.security.ssl.SSLSocketImpl.readRecord(Unknown Source) at sun.security.ssl.SSLSocketImpl.performInitialHandshake(Unknown Source) at sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source) at sun.net.www.protocol.https.HttpsClient.afterConnect(Unknown Source) at sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.connect(Unknown Source) at sun.net.www.protocol.http.HttpURLConnection.getInputStream0(Unknown Source) at sun.net.www.protocol.http.HttpURLConnection.getInputStream(Unknown Source) at java.net.HttpURLConnection.getResponseCode(Unknown Source) at sun.net.www.protocol.https.HttpsURLConnectionImpl.getResponseCode(Unknown Source) at org.eclipse.jgit.transport.http.JDKHttpConnection.getResponseCode(JDKHttpConnection.java:99) at org.eclipse.jgit.util.HttpSupport.response(HttpSupport.java:202) at org.eclipse.jgit.transport.TransportHttp.connect(TransportHttp.java:500) ... 72 more Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at sun.security.validator.PKIXValidator.doBuild(Unknown Source) at sun.security.validator.PKIXValidator.engineValidate(Unknown Source) at sun.security.validator.Validator.validate(Unknown Source) at sun.security.ssl.X509TrustManagerImpl.validate(Unknown Source) at sun.security.ssl.X509TrustManagerImpl.checkTrusted(Unknown Source) at sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(Unknown Source) ... 89 more Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target at sun.security.provider.certpath.SunCertPathBuilder.build(Unknown Source) at sun.security.provider.certpath.SunCertPathBuilder.engineBuild(Unknown Source) at java.security.cert.CertPathBuilder.build(Unknown Source) ... 95 more
The SSL-certificate of the GitLab-webserver is trusted by Google Chrome when I try to access GitLab from the ThingWorx server.
There seems to be something else that has to be configured to make this working. We are using a self-signed certificate in .local domain.
Any help is appreciated. Thank you.
18-Opal
I would think that your self-signed certificate is an issue. The fact that you "trust" it in your Chrome doesn't mean that the JVM running ThingWorx would know anything about it and/or do the same. A couple of suggestions:
1. Add this self-signed certificate to ThingWorx' JVM trust store. You'll find plenty of examples of how to do it, e.g. here.
2. Don't use self-signed certificates, get a proper domain name and certify it, at least via LetsEncrypt.
Constantine
pjahn16-PearlAuthor
I agree that a .local domain is not optimal. The customer has his own CA and this root certificate authority is configured as trustworthy for the entire infrastructure (servers, clients, ...). Since the CN is also included in the certificate for GitLab, the certificate is also trustworthy for Chrome. But you're probably right: The certificate must be in the keystore we configured for ThingWorx. I'll try that soon.
SwapnilP
Hi @pjahn
I am having same situation like you and getting same error.
Please share the steps of resolution if you have resolved it. Thank you.
Swapnil
