Corresponding Starting/closing bracket is not shown if lines of code in between is >= 100
  • October 6, 2016
  • 3 replies
  • 2479 views
Hi Team,
When used to write more number of lines of code in thingworx based our need/requirements.we observed that closing/Starting bracket is not shown correspondingly if the lines of code between them is  equal or greater than 100 lines.
If you could resolve this, it would be helpful.
Thanks.
Hi Rdhakrishnan Kandasamy​ Thank-you for bringing to us , which you thing could be a potential bug. Please help us understand the problem .
Please explain in little detail what you are saying  , like , are you pointing to , while writing services or some Extension development code.
Please share screenshot as well. Your help would greatly be appreciated if shared with Steps of replication along with version of Thingworx , you are quoting here.
Thank you once again !
Ravi Upadhyay
Hi Ravi,
i am using thingworx version 7.1.0-b484. I am seeing this problem while writing thingworx service code(javacript).
To Replicate:
Open any thing and add a new service and inside that:
If( 2 == 2)
logger.info("Two is equal to two");
Now just try increasing the number of lines as empty lines between open/close bracket till reaches more than hundred. So the corresponding start/close bracket won't be highlighted after 100 line count.
Thanks.
Rdhakrishnan Kandasamy​,
I can reproduce this issue. Can you please open case with PTC TS to report it to R&D.
Ankit Gupta
Hi Rdhakrishnan Kandasamy​,
On which ThingWorx version you are o?. Can you please share a Screenshot of what you mean.
I tried to create a service with if statement containing more than 100 lines of JavaScript code and I can see the start/closing bracket in ThingWorx 7.2.3.
Ankit Gupta
Thank-you for sharing the replication steps. Will try to reproduce on exactly same build and will inform you about my findings on this. If its bug , we will report to our Development team.
Thank-you once again for taking out time and reporting this to us. Highly appreciated.
On a slightly different note , have tried this on some different development IDEs , is it working okay there ?
