Create template by snippet
  • April 14, 2017
  • 6 replies
  • 2428 views
Hi, i need to create a template by snippet.
I figured out this method but i can't see on the template list my new template and if i try to recreate it i receive the message "can't create template 'MyCustomNameTemplate' template already exist", i had this problem when i tryed to create a thing but i didn't restart it and enable it. Is there any similar method for templates ?
var paramsRemoteThing = {
    description: "my personal description",
    thingTemplateName: 'RemoteThing',
    tags: 'MyApp:Template'
Resources["EntityServices"].CreateThingTemplate(paramsRemoteThing);
//here i need some code for enable template and see it in the template's list.
thank you !!!
Alberto, was that snippet part of a service that failed? If it says 'template already exists' and you can't see it, you've essentially created a ghost entity; that's an entity that exists in memory but is not committed to the database. You would always need to use a try-catch block around create scripts so that you avoid creating ghost entities.
If you have ThingWorx 7.2.0+, please take a look at our Ghost Entities Cleaner extension in our Marketplace. Here is a KCS article that expands on the topic of detection, prevention and removal of said entities. With that being said, the create code you provided should work (on its own).
aziliotto12-AmethystAuthor
No the script did'nt failed, and for solving ghost entities i stopped tomcat and restart.
But also with try catch i can't see the template on the template list so i imagine there is some code to enable it like creating things...
I am having the same Issue.
