Creating Map Mashup with 100 points
  • October 16, 2017
  • 14 replies
  • 5646 views
I am trying to create a openmap mashup that shows multiple points (100) on it with specific information as you click on each point. I am new to the Thingworx software but I was able to plot many different things using bar graphs and now I am having trouble mapping coordinates. I take the steps below to upload a csv file using parsley and create a mashup but when it comes to mapping the separate points the map is blank (see attachments).
  1. Create a CSV with the correct Longitude and Latitude formatting. I used the Location formatting that is specified on the PTC website (http://support.ptc.com/cs/help/thingworx_hc/thingworx_7.0_hc/index.jspx?id=ThingProperties&action=show). On this site it shows the Location format should be Location = [longitude, latitude]. While on the Mashup it puts the location formatting as Location = [latitude, longitude] I tried uploading the data both ways and also with and without brackets.
  2. I upload the CSV using Parsley and the data is shown is services.
  3. Then I Execute the program in service to check if the data transferred over as needed. As shown in the screenshot attached.
  4. I save the information and the data shape. Create a visual mashup click and drag the open maps template over and transfer all data into the graph.
  5. In the Locations field I put LatLong and leave everything else alone and click view mashup.
  6. Doing so creates a blank map with only one dot that is on london.
Please let me know if you need more information.
You need the LatLong column to be of type Location. The Location type takes three parameters: Latitude, Longitude, Elevation. Try removing the brackets and adding a 0.0 to the end of each value.
fumrigar1-VisitorAuthor
Al,
Thank you for the quick response I changed my values in the CSV file as you recommended, it didn't work. I changed the value to 29.7,78.52,0.0 and reuploaded the file. I was reading online and i wonder if this has to do with js snippet I used. Below is the snippet, is this in the right format to read the data?
Do I need to split up the two columns into longitude and latitude? or should I leave it combined?
Hi, the "LatLong" must be of type LOCATION. You need to convert the data parsed in that type. For example:
var location = new Object();
location.latitude = Latitude;
location.longitude = Longitude;
location.elevation = 0;
location.units = "WGS84";
Than something like:
data.LatLong = location;
I apologize I have little to no experience with javascript. As I understand from the above suggestion I need convert the parsed data to a location type. Is there anyway someone can write the js code or show me a working example? Currently in my Services I have the below code what should I add to the code so that it reads the excel column above with the latitude and longitude?
var params = {
path: "/CSV_January_UP.csv" /* STRING */,
hasHeader: true /* BOOLEAN */,
//dateFormat: undefined /* STRING */,
fileRepository: me.name /* THINGNAME */,
//latitudeField: undefined /* NUMBER */,
fieldDelimiter: "," /* STRING */,
stringDelimiter: '"' /* STRING */,
//dataShape: undefined /* DATASHAPENAME */
// result: INFOTABLE
var result = Resources["Parsley"].ParseCSV(params);
Do I add the suggested code here? Also what do I add where it says (data).
In step 3 you are getting an infotable that has the location info from your CSV file. So you just need to modify this infotable to add a column with a base type of "LOCATION" and then pass the latitude longitude information to create data. So in your excel store latitude and longitude in 2 separate columns for easy access during conversion process. Try to follow below steps,
1. Lets say you call the infotable from ParseCSV service as location table
     var locationTable= Resources["Parsley"].ParseCSV(params);
2. Modify this table to add a column called location
var newField = new Object();
        newField.name = "location";
        newField.baseType = 'LOCATION';
        locationTable.AddField(newField);
3. Now loop through the table to read the longitude and latitude columns and convert them into location field
     for (var i=0;i<locationTable.rows.length;i++){
     var row=locationTable.rows
     var templocation = new Object();
     templocation.latitude = row.Latitude;  //this is the coulmn where latitude got loaded from CSV
     templocation.longitude = row.Longitude; //this is the coulmn where longitude got loaded from CSV
     templocation.elevation = 0;
     templocation.units = "WGS84";
locationTable.rows.location =templocation
var result = locationTable
now the result table should have the new column with Location data type that will display on the map. I have not tested this code but some modification may be required if you run into syntax issues !! Hopefully it works on the 1st run
