Custom authenticator
Hello Community,
I have been trying to create a custom authenticator. It's actually based on a parameter that I can get from the httpRequest. What i need to know is how can I, in case this parameter is absent, go back to the default authenticator.
I already done a test if it's present or not in order to return false and then the next Authenticator in the chain will be given a chance to handle the request and so on until a valid Authentication occurs.
| @Override | |||
| public boolean matchesAuthRequest(HttpServletRequest req) throws AuthenticatorException { | |||
| // TODO Auto-generated method stub | |||
| if(req.getParameter("parameter1") !=null){ return true;} | |||
| else {return false ;} | |||
Best regards,
