Data Analysis Definitions
  • December 18, 2017
  • 1257 views
I am trying to define the data analysis definitions following the instructions Digital Media Publisher . While defining the features the composer is not taking more than one or rather I should say that it automatically takes in the first 'goal' in the table only irrespective of the feature name and data source I am selecting. Is there a way to work around this problem and what maybe the reason for it?
Thanks!
P.S. I am taking a Thing property as the data source and whenever I am trying to add more a feature and save it, the composer simply doesn't save the changes.
Also while taking datasource as a service, even after selecting the required values which are needed to be sent, the done button is not highlighted and hence not allowing me to save the changes.
Hi Tushar
I would recommend you look at this blog: How to use DataConnect when sending property values from the ThingWorx platform to ThingWorx Analytics.
it should give you a better understanding of the DAD.
Hope this helps
Kind regards
Christophe
