Data Driven Menu Issue
  • January 15, 2015
  • 6 replies
  • 3112 views
I am trying to use a data driven menu.  I have a table that is configured with columns that match the MenuEntry Data Shape.
column names:
description
imageURL
isDefault
linkDestination
linkTarget
linkType
menuId
parentMenuId
titlle
This is the data in the that table:
A
NULL
False
http://server:8181/Thingworx/Runtime/index.html#master=&mashup=Metrics Dashboard&Team=A
New
Hyperlink
Teams_0
Teams
A
B
NULL
False
http://server:8181/Thingworx/Runtime/index.html#master=&mashup=Metrics Dashboard&Team=ACS.T1
New
Hyperlink
Teams_1
Teams
B
Teams
NULL
NULL
NULL
Menu
Teams
NULL
Teams
I then created a service that returns an infotable and uses the data shape MenuEntry.  I then placed the menu widget down on the mashup and linked the service data to the menudata and selected datadriven.  No data is being returned in runtime.  Any thoughts/ideas?
    I've never worked with the menu as Data Driven but what I do see sometimes with a Tree widget, is that it can't render if a value is NULL.
    Perhaps you can try with the value set to "" instead.
    keriw1-VisitorAuthor
    Thanks for the idea PaiC, unfortunately it didn't resolve the issue.
    Have you verified that the information comes into the mashup by putting it into a grid? This is a great way to check if information arrives in an infotable.
    Also I would create this menu as a defined/configured menu and run the GetEffectiveMenu service into another grid, allowing you to compare what you are generating vs. what Thingworx natively would generate for a Menu widget.
    Yes, I verified that it is coming into a grid correctly.  Everything looks perfect.
    Keri,
    Based on my testing, the null values do not appear to affect the Menu widget. However, if you're capitalizing NULL and False as you are in the example data you provided, this will likely create issues as JavaScript keywords are case-sensitive.
    I was able to get a data-driven Menu working in a Mashup by observing the JSON data returned by the GetEffectiveMenu Service when using the widget with the configured option. Using this structure as a reference, I programmatically created a Menu with two hyperlinks and a menu. Below, I'll briefly describe the process:
    Add a Row for the Top-level Menu
    After creating an InfoTable with the appropriate DataShape (MenuEntry), I add a row for the top-level menu:
    var row = new Object();
    row.menuId = "Menu1";
    row.linkType = "Menu";
    result.AddRow(row);
    Next, I add the hyperlink menu items:
    row.parentMenuId = "Menu1";
    row.menuId = "Menu1_1";
    row.title = "Google";
    row.linkType = "Hyperlink";
    row.linkDestination = "http://google.com";
    row.linkTarget = "New";
    row.isDefault = false;
    result.AddRow(row);
    Add a Row for the Nested Menu
    row.menuId = "Menu1.Menu2";
    row.title = "More";
    result.AddRow(row);
    Lastly, I add a row for the menu item of the nested menu:
    row.parentMenuId = "Menu1.Menu2";
    row.menuId = "Menu1.Menu2_0";
    row.title = "ThingWorx";
    row.description = "ThingWorx";
    row.linkDestination = "http://thingworx.com";
    result.AddRow(row);
    Obviously, you'll generate this InfoTable differently depending on your use case, but this should help you get the necessary information in the InfoTable for the Menu. Speaking of your use case, would you mind sharing it? I'm curious to know why you would need to use a data-driven Menu.
    Adam
    Great, I will give that a try.  Our main menu for our system is a list of teams that is dynamic in nature, a team name can change or a new team could be added or deleted from the database.  I have substituted with a basic list in the interim but would like to have the more robust features that the menu provides and the capability for icons.
