Data Filter Widget
Hi Guys,
When using the data filter widget is there anyway to limit the fields that are able to be chosen for filtering. As a data table has fields automatically created (source, location, key, etc) I think the end user will find them distracting if they are not in use. For instance do we need to have the location field as an optional search criteria when location is not being used at all.
Regards, Kim
