Data Storage
  • March 8, 2016
  • 3 replies
  • 3665 views
I'm curious about the data storage limits on streams, blogs, data tables, etc. How much data can generally be saved in these entities if using a platform that is hosted by TW? If business needs exceed these limits what are other options of data storage and archiving? Is there somewhere to view that storage used vs available?
Good question, I have a case opened for a long time without answer about DataTable "limits".
Even I'm not sure of the limits of TW hosted instance.
There are few options available for extended data storage and archival.
You can create a Thing that uses a Database Thing template to connect to any external Databases or archive it on NoSQL clusters etc. However, these external storage should be self hosted or subscribed to any 3rd party hosting services.
Hi Jenna,
Please refer this link of an Article which talks about data storage limits of Streams/Data Tables :
     https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS204089&lang=en_US
But 100k it's not Big Data, it's just a few registers....
Hi Carles,
For larger data you need to switch to external Database
