Jamal Ashraf
Sep 10, 2025 12:45 PM UTC
Distinct Values from an InfoTable in Mashup (without extra service)?
Hi Community,
I have an InfoTable with several fields, and I would like to use one of those fields as the source for a Dropdown widget. The issue is that this field can contain duplicate values, but in the dropdown I only want to show distinct values.
Right now, the only way I see is to create a separate service that takes the InfoTable and returns only the distinct entries.
 My question: Is there any way to achieve this directly in the mashup (e.g., via Data Filter, Query, or some built-in option) without having to write an additional service?
Thanks in advance for your ideas!
Jamal Ashraf
Sep 12, 2025 6:35 AM UTC
Yes There is no way to have distinct values in the dropdown. One can only do this with a service. Secondly There is also no way to use infotable in validators or expressions. if a developer wants to do small operations directly in the mashup then he cannot do that untill he has a small extension which can convert infotable to JSON and then one can use it validator and expressions. Anyways i have my answer.
Sep 11, 2025 3:46 PM UTC
Hello @MA8731174 ,
I do not believe that there are any options to filter the items which appear in the dropdown in a grid.
Is there a reason why you are trying to avoid using a service to define the list?
Pehowe
Jamal Ashraf
Jamal Ashraf16-PearlAuthorAnswer
