duplicated key in DataTable
  • September 3, 2015
  • 4 replies
  • 1863 views
When I call AddDataTableEntry or AddOrUpdateDataTableEntry very quickly, two data row with same key will be added.
How to settle it?
Both serialNumber and alarmType are primary key. I have test unique primary key, but same error.
Code:
var query = {
  "filters": {
    "type": "AND",
    "filters": [
        "fieldName": "serialNumber",
        "type": "EQ",
        "value": serialNumber
        "fieldName": "alarmType",
        "type": "EQ",
        "value": alarmType
var params = {
    query: query,
    maxItems: 1
var old_times = 0;
var cc = Things["AlarmTimesTable"].QueryDataTableEntries( params );
if ( cc !== undefined && cc.getRowCount() != 0 ) {
    old_times = cc.getRow(0).times;
    //var values = cc;//.getRow(0);
var values = Things["AlarmTimesTable"].CreateValues();
values.gateway = me.name;
values.updateTime = updateTime;
values.serialNumber = serialNumber;
values.alarmType = alarmType;
values.times = old_times + 1;
var params = {
    //source :  me.name,
    values : values,
Things["AlarmTimesTable"].AddOrUpdateDataTableEntry( params );
logger.error("out");
    cdu1-VisitorAuthor
    "very quickly" means two http request at same time
    i met the same issue, and the only way to fix it is to create a service that locate duplicate and suppress them.
    Seems there is  a delay before a newly written entry can be read
    cdu1-VisitorAuthor
    Hi Laurent,
    I noticed that 6.5 settle the issue, but the second http request will report error, i.e. one of data be dropped.
    I think the better solution is multithreading-locking, and a delay after Add ( not Update ) like you said.
    Do you know is there any mutex/critical_section/thread_lockig functions? or task queue for one thread ?
