dynamically create a service in ThingWorx 9.3 using JavaScript code:
hi expert ,
this code not working i get code Chatgpt ,
var entity = ThingUtilities.findThing("ThingName");
// Create a new ServiceDefinition object
var serviceDefinition = new ServiceDefinition({
description: "This is a new service.",
remote: false,
allowOverride: false
// Add inputs and outputs to the service definition dynamically
serviceDefinition.addInput({
description: "",
baseType: "STRING"
description: "",
baseType: "INTEGER"
description: "",
baseType: "DATETIME"
serviceDefinition.addOutput({
description: "",
baseType: "INTEGER"
description: "",
baseType: "STRING"
// Add the service definition to the Thing or Thing Template
entity.addServiceDefinition(serviceDefinition);
// Save the changes to the Thing or Thing Template
entity = ThingUtilities.saveEntity(entity);
// Restart the Security service to ensure that the new service is visible to all users
var securityService = SecurityContextFactory.getSecurityContext().getSecurityService();
securityService.restart(Resource.SERVICE);
refer Create a service dynamically
Below code helpful to create service with input and output alone.
// CreateInfoTableFromDataShape(infoTableName:STRING("InfoTable"), dataShapeName:STRING):INFOTABLE(FieldDefinition)
var input = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape({
 infoTableName: "InfoTable",
 dataShapeName: "FieldDefinition"
let newEntry = {
 name: "result", // STRING [Primary Key]
 description: undefined, // STRING
 isPrimaryKey: undefined, // BOOLEAN
 baseType: "STRING", // BASETYPENAME
 dataShape: undefined // DATASHAPENAME
input.AddRow(newEntry);
me.AddServiceDefinition({
	name: "test_service" /* STRING */,
	description: undefined /* STRING {"defaultValue":""} */,
	remoteServiceName: undefined /* STRING */,
	category: undefined /* STRING */,
	remote: undefined /* BOOLEAN {"defaultValue":false} */,
	parameters: input /* INFOTABLE {"dataShape":"FieldDefinition"} */,
	resultType: input /* INFOTABLE {"dataShape":"FieldDefinition"} */,
	timeout: undefined /* INTEGER {"defaultValue":0} */
let newEntry = {
Hi @Sathishkumar_C
thanks to support
with regards
Hariharasuthan
