Enable / Disable button
  • June 3, 2014
  • 6 replies
  • 2580 views
Is there a way to disable a button based on a validation otp, I know how to set the visible attbte, but I dunno how to enable / disable the button.
Thanks Adam & regards.
    Currently we don't have the ability to disable buttons.
    Hello Pai:
    So what is the approach or suggestion that you will make to me, I can't let the user click the button if the condition is not going, I used the Show Message to let the user know, but I need sometime else.
    If your use case permits it, you can bind the visibility property of the button to the output of your validator widget. If the output is true, the button will be visible, and if it if false, it will now.
