Error in Aggregating Stream Data
  • January 27, 2012
  • 2399 views
<p><p class="MsoNormal">I apologize for reposting this, but since you folks are so
wonderful at responding so quickly and since I did not get a near-instantaneous
response on this one, I figure it might be because it got lost in the last
thread.<o:p></o:p></p>
<p class="MsoNormal"><o:p> </o:p>I am having problems aggregating the values from one of my
data streams. I keep getting ‘Execution error in service script: Wrapped
java.lang.NullPointerException’ errors in the logger. I can see that the
GetStreamEntiresWithData call is working fine and I get a significant number of
rows coming back (I moved the for each snippet up and commented out the
aggregate call). However, it seems like it keeps failing when I go to call the
Aggregate function (I do not see the count posted at all in the logger when I
try to get it from the Aggregate result). I originally had it where I was
reusing the result and params variables like Andy’s earlier example, but I
changed them to see if they were the ones causing the issue; does not look like
that is the culprit. I also double-checked the column names but they are all
correct (including case). Any ideas on what I might be doing wrong? Thanks!</p><p class="MsoNormal"><o:p></o:p></p>
<p class="MsoNormal"><o:p> </o:p></p>
<p class="MsoNormal">var result = new Object();<o:p></o:p></p>
<p class="MsoNormal"><o:p> </o:p> </p>
<p class="MsoNormal">var StreamParams = {<o:p></o:p></p>
<p class="MsoNormal">                oldestFirst
: false,<o:p></o:p></p>
<p class="MsoNormal">                maxItems
: 500<o:p></o:p></p>
<p class="MsoNormal">};<o:p></o:p></p>
<p class="MsoNormal">// GetStreamEntriesWithData(oldestFirst:BOOLEAN,
maxItems:NUMBER(500)):INFOTABLE(ProductDataShape)<o:p></o:p></p>
<p class="MsoNormal">result =
Things['SSProductionStream'].GetStreamEntriesWithData(StreamParams);<o:p></o:p></p>
<p class="MsoNormal">var result2 = new Object();<o:p></o:p></p>
<p class="MsoNormal">var AggParams = {<o:p></o:p></p>
<p class="MsoNormal">                t :
result,<o:p></o:p></p>
<p class="MsoNormal">                aggregates
: "SUM,SUM,SUM",<o:p></o:p></p>
<p class="MsoNormal">                columns
: "Rejects,EnergyUsage,WaterUsage",<o:p></o:p></p>
<p class="MsoNormal">                groupByColumns
: "ProductID"<o:p></o:p></p>
<p class="MsoNormal">// Aggregate(t:INFOTABLE, aggregates:STRING, columns:STRING,
groupByColumns:STRING):INFOTABLE(Undefined)<o:p></o:p></p>
<p class="MsoNormal">result2 =
Resources['InfoTableFunctions'].Aggregate(AggParams);<o:p></o:p></p>
<p class="MsoNormal">var count = 0;<o:p></o:p></p>
<p class="MsoNormal">for each (var line in result2.rows) {<o:p></o:p></p>
<p class="MsoNormal">count++;<o:p></o:p></p>
<p class="MsoNormal">}<o:p></o:p></p>
<p class="MsoNormal">logger.warn(count);<o:p></o:p></p></p>
Hi Brian that error generally means there is a syntax issue somewhere. Not sure if all those columns were defined by you, but I know Andy uses camelBack notation so it would be rejects, energyUsage, waterUsage. (shouldn't give the Java lang error though I think)
Can you try it the following way to see if it makes a difference:
Put columns before aggregates (although this shouldn't matter)
or put it all in the call like:
result2 = Resources['InfoTableFunctions'].Aggregate({"t":result, "columns":"Rejects,EnergyUsage,WaterUsage", "aggregates":"SUM,SUM,SUM", "groupByColumns":"ProductID"});
