ERROR: No Stream Entry ID Was Provided?
  • July 1, 2016
  • 6 replies
  • 3723 views
As I was checking my logs yesterday, I noticed that within the ApplicationLog that I was getting a "No Stream Entry ID Was Provided" for whomever is logged in.  I've seen this with the Administrator account and other users' accounts.  Is there anything at a User level that I am missing here?  I've looked through Thingworx and just can't seem to find anywhere where I am suppose to be providing an ID for a Stream.  Any help would be appreciated.  Thanks and here's the error!
[context: com.thingworx.webservices.context.HttpExecutionContext@d72d785][message: No Stream Entry ID Was Provided]
Tom, does this get printed out once when a user logs in, or is it a recurring message every minute or so? Do you have any custom User Extensions properties?
tadkins11-VisitorAuthor
Thanks for the reply.  It appears it is happening every minute or so once the user logs in.  The only extensions I'm using are Mail_Extensions, GoogleWidgets_ExtensionPackage, MYSQL_ExtensionPackage, and Twilio_Extensions.
Thanks for the clarification, Tom. By User Extensions, I meant the User properties. Click on any User, and then go to the User Extension section. What are the available fields/ properties?
