Error while parsing CSV file in Axeda
  • April 5, 2017
  • 1990 views
Hi
I am using the below code to parse a CSV file but when I run the code in Axeda Server 6.5 I get the error as groovy.lang.MissingPropertyException: No such property: compressedFile for class
  1. import com.axeda.drm.sdk.Context
  2. import com.axeda.drm.sdk.device.DeviceFinder
  3. import com.axeda.drm.sdk.device.ModelFinder
  4. import com.axeda.drm.sdk.device.DataItemFinder
  5. import com.axeda.drm.sdk.device.DataItem
  6. import com.axeda.drm.sdk.data.DataValueEntry
  7. import java.util.regex.Pattern
  8. import groovy.json.*
  9. import com.axeda.drm.services.device.DataItemType
  10. import net.sf.json.JSONObject
  11.
  12. /**
  13. * CSVToData.groovy
  14. * -----------------------
  15. *
  16. * Executed from an expression rule with file hint "datainsert", takes a CSV file and adds data based on values.
  17. *
  18. * @note  There must be a column with "model" and one with "serial".  The rest of the columns should be data item names with values
  19. * in the rows. DOES NOT handle null values in CSV.  Workaround is to insert blank spaces in null values and test for those on the Groovy side.
  20. * Solution would be to add a library for CSV parsing such as open csv.
  21. *
  22. * @params - only needed if NOT executed from expression rule - primarily for debugging
  23. * modelName - (OPTIONAL) Str - name of the model
  24. * serialNumber - (OPTIONAL) Str - name of the serial number
  25. *
  26. *
  27. */
  28.
  29. /**
  30. * initialize our global variables
  31. * json = the contents of our response
  32. * infoString = a stringBuilder used to collect debug information during the script
  33. * contentType = the content type we will return
  34. * scriptname = The name of this Script, used in multiple places
  35. */
  36. def json = new groovy.json.JsonBuilder()
  37. def infoString = new StringBuilder()
  38. def contentType = "application/json"
  39. def scriptName = "CSVToData.groovy"
  40. def root = ["result":["items":[]]]
  41.
  42. def columns = []
  43.
  44. try
  45.
  46.   Context CONTEXT = Context.getSDKContext()
  47.
  48.   def modelIndex
  49.   def serialIndex
  50.
  51.   // initialize Model and Device Finders
  52.   ModelFinder modelFinder = new ModelFinder(CONTEXT)
  53.   DeviceFinder deviceFinder = new DeviceFinder(CONTEXT)
  54.
  55.   // implicit object compressedFile
  56.   File file = compressedFile.getFiles()[0].extractFile()
  57.
  58. /* //begin non-expression rule code, useful for debugging
  59.     File file
  60.     modelFinder.setName(Request.parameters.modelname)
  61.               def model1 = modelFinder.find()
  62.     deviceFinder.setSerialNumber(Request.parameters.serialNumber)
  63.     deviceFinder.setModel(model1)
  64.     def d = deviceFinder.find()
  65.      UploadedFileFinder uff = new UploadedFileFinder(CONTEXT)
  66.     uff.device = d
  67.     def ufiles = uff.findAll()
  68.     UploadedFile ufile
  69.     if (ufiles.size() > 0) {
  70.         ufile = ufiles[0]
  71.         file = ufile.extractFile()
  72.     }
  73.
  74. */ //end non-expression rule code
  75.
  76.   file.eachLine {line ->
  77.       def row = line.tokenize(','
  78.
  79.       // set the column headings
  80.       if (columns.size() == 0){
  81.         columns = row
  82.
  83.         // find model and serial index, assumes there's a column that has "model" and "serial", otherwise take columns 0 and 1
  84.         def modelpatt = Pattern.compile(/[A-Za-z_\-]{0,}model[A-Za-z_\-]{0,}/, Pattern.CASE_INSENSITIVE)
  85.         def serialpatt = Pattern.compile(/[A-Za-z_\-]{0,}serial[A-Za-z_\-]{0,}/, Pattern.CASE_INSENSITIVE)
  86.         modelIndex = columns.findIndexOf{ it ==~ modelpatt } > -1 ? columns.findIndexOf{ it ==~ modelpatt } : 0
  87.         serialIndex = columns.findIndexOf{ it ==~ serialpatt } > -1 ? columns.findIndexOf{ it ==~ serialpatt } : 1
  88.
  89.       }
  90.       // otherwise populate data
  91.       else
  92.
  93.           modelFinder.setName(row.get(modelIndex))
  94.           def model = modelFinder.find()
  95.
  96.           deviceFinder.setModel(model)
  97.           deviceFinder.setSerialNumber(row.get(serialIndex))
  98.
  99.           def device = deviceFinder.find()
  100.
  101.           def assetInfo = [
  102.                     "model": model.name,
  103.                     "serial": device.serialNumber,
  104.                     "data":[]
  105.                     ]
  106.
  107.           row.eachWithIndex{ item, index ->
  108.               if (index != modelIndex && index != serialIndex){
  109.                 def dataItemName = columns[index].replace(" ",""
  110.                 DataItemFinder dif = new DataItemFinder(CONTEXT);
  111.                 dif.setDataItemName(dataItemName);
  112.                 dif.setModel(model);
  113.                 DataItem dataItem = dif.find();
  114.
  115.                 if (dataItem){
  116.                     if (item.isNumber()){
  117.                        item = Double.valueOf(item)
  118.                     }
  119.                     DataValueEntry dve = new DataValueEntry(CONTEXT, device, dataItem, item)
  120.                     dve.store()
  121.                 }
  122.                 else
  123.                     DataItem newDataItem
  124.                     if (item.isNumber()){
  125.                         newDataItem = new DataItem(CONTEXT, model,DataItemType.ANALOG, dataItemName)
  126.                         item = Double.valueOf(item)
  127.                     }
  128.                     else
  129.                        newDataItem = new DataItem(CONTEXT, model,DataItemType.STRING, dataItemName)
  130.                     }
  131.                    newDataItem.store()
  132.                    DataValueEntry dve = new DataValueEntry(CONTEXT, device, newDataItem, item)
  133.                     dve.store()
  134.                 }
  135.                 assetInfo.data << [
  136.                         "name": dataItemName,
  137.                         "value": item
  138.                     ]
  139.
  140.               }
  141.               root.result.items << assetInfo
  142.           }
  143.
  144.       }
  145.   }
  146.   logger.info(JSONObject.fromObject(root).toString(2))
  147.
  148. } catch (Exception e) {
  149.
  150.     processException(scriptName,json,e)
  151.
  152. //return ['Content-Type': 'application/json', 'Content': JSONObject.fromObject(root).toString(2)]
  153.
  154.
  155.
  156. /*
  157.     Processes the contents of an Exception and add it to the Errors collection
  158.     @param json The markup builder
  159. */
  160. private def processException(String scriptName, JsonBuilder json, Exception e) {
  161.     // catch the exception output
  162.     def logStringWriter = new StringWriter()
  163.     e.printStackTrace(new PrintWriter(logStringWriter))
  164.     logger.error("Exception occurred in ${scriptName}: ${logStringWriter.toString()}"
  165.
  166.     /*
  167.         Construct the error response
  168.         - errorCode Will be an element from an agreed upon enum
  169.         - errorMessage The text of the exception
  170.      */
  171.     json.errors  {
  172.         error {
  173.             message     "[${scriptName}]: " + e.getMessage()
  174.             timestamp   "${System.currentTimeMillis()}"
  175.         }
  176.     }
  177.
  178.     return json
Try importing com.axeda.drm.sdk.scm.CompressedFile
import com.axeda.drm.sdk.scm.CompressedFile
Regards
Arunkumar D
http://www.arundhaj.com/
