Export Data problem
  • February 16, 2016
  • 1485 views
Hi guys,
I need to export my data for the 7.0 upgrade.
But After I clicked the Export Data it popped out this.
My version is 6.6 b148
Data Export submitted for processing. Please check the log for completion status of Task-1455594985789
How can I fix this??
22-Sapphire I
February 16, 2016
Did you check the application Log to see if the export succeeded? The export now goes to a FileRepository on the Server.
I have the same problerm. How can I import the exported data in other environment? With the file it was easy. What can I do now?
Thanks!
Javier, did you export to ThingworxStorage? If so, you should have a new folder under ThingworxStorage/ exports with the following name format - yyyymmddhhmmss. You can just zip that folder, move it over to your new environment's ThingworxStorage/ exports folder and unzip that. Once you go to Import/ Export -> Import from ThingworxStorage, you should be able to select this folder.
