Extension - ThingTemplate - SetHomeMashup
  • September 13, 2016
  • 2 replies
  • 1877 views
I am developping an extension for ThingWorx, and I can't find a way to set the HomeMashup for a ThingTemplate.
I tried using com.thingworx.entities.RootEntity.SetHomeMashup(String name) with my template mashup's name, in initializeEntity() and in initialiazeThing(), but when I load my extension on the server the HomeMashup setting is blank.
I tried setting it with a JavaScript service on the server, and it works :
var params = {
    name: "SLBTemplateMashup" /* MASHUPNAME */
// no return
ThingTemplates["SLBThingTemplate"].SetHomeMashup(params);
Is there another way to set the HomeMashup on a ThingTemplate from the extension ? Am I missing something ?
Thank you for your answers.
Hi Pierre,
Try following and see if it helps:
ThingTemplate tt = (ThingTemplate) EntityUtilities.findEntity("Thing_Template_Name_Here", ThingworxRelationshipTypes.ThingTemplate);
tt.SetHomeMashup("Home_Mashup_Name_Here");
You would need to import:
import com.thingworx.thingtemplates.ThingTemplate;
import com.thingworx.entities.utils.EntityUtilities;
Hope it helps.
Ankit Gupta
pborderie1-VisitorAuthor
I tried it in initializeEntity(), initializeThing() and processStartNotification(), it doesn't work, HomeMashup is not set.
Here is a part of my code :
@ThingworxBaseTemplateDefinition(name = "RemoteThing")
@ThingworxPropertyDefinitions(properties = { @ThingworxPropertyDefinition(name = "S1", description = "", category = "Outputs", baseType = "NUMBER", isLocalOnly = false, aspects = { "dataChangeType:Always", "isRemote:true", "units:%", "isLogged:true" }), @ThingworxPropertyDefinition(name = "S2", description = "", category = "Outputs", baseType = "NUMBER", isLocalOnly = false, aspects = { "dataChangeType:Always", "isRemote:true", "units:%", "isLogged:true" }), @ThingworxPropertyDefinition(name = "S3", description = "", category = "Outputs", baseType = "NUMBER", isLocalOnly = false, aspects = { "dataChangeType:Always", "isRemote:true", "units:%", "isLogged:true" }), @ThingworxPropertyDefinition(name = "S4", description = "", category = "Outputs", baseType = "NUMBER", isLocalOnly = false, aspects = { "dataChangeType:Always", "isRemote:true", "units:%", "isLogged:true" }), @ThingworxPropertyDefinition(name = "S5", description = "", category = "Outputs", baseType = "NUMBER", isLocalOnly = false, aspects = { "dataChangeType:Always", "isRemote:true", "units:%", "isLogged:true" }), @ThingworxPropertyDefinition(name = "S6", description = "", category = "Outputs", baseType = "NUMBER", isLocalOnly = false, aspects = { "dataChangeType:Always", "isRemote:true", "units:%", "isLogged:true" }) })
public class SLBThingTemplate extends RemoteThing {
    protected static Logger _logger = LogUtilities.getInstance().getApplicationLogger(SLBThingTemplate.class);
    @Override
    public void initializeEntity() throws Exception {
        super.initializeEntity();
        _logger.info("in:SLBThingTemplate.initializeEntity()");
        ThingTemplate tpl = (ThingTemplate) EntityUtilities.findEntity("SLBThingTemplate", ThingworxRelationshipTypes.ThingTemplate);
        _logger.info(tpl.getName() + " found!");
        _logger.info("(before set) HomeMashup = " + tpl.GetHomeMashup());
        tpl.SetHomeMashup("SLBTemplateMashup");
        _logger.info("(after set) HomeMashup = " + tpl.GetHomeMashup());
//        SetHomeMashup("SLBTemplateMashup"); // doesn't work
        // automatically bind properties to remote properties exposed by the remote device
        // Outputs:
        this.SetRemotePropertyBinding("S1", "S1", 0, DataChangeType.NEVER.toString(), 0.);
        this.SetRemotePropertyBinding("S2", "S2", 0, DataChangeType.NEVER.toString(), 0.);
        this.SetRemotePropertyBinding("S3", "S3", 0, DataChangeType.NEVER.toString(), 0.);
        this.SetRemotePropertyBinding("S4", "S4", 0, DataChangeType.NEVER.toString(), 0.);
        this.SetRemotePropertyBinding("S5", "S5", 0, DataChangeType.NEVER.toString(), 0.);
        this.SetRemotePropertyBinding("S6", "S6", 0, DataChangeType.NEVER.toString(), 0.);
        _logger.info("out:SLBThingTemplate.initializeEntity()");
    @Override
    public void initializeThing() throws Exception {
        super.initializeThing();
        _logger.info("in:SLBThingTemplate.initializeThing()");
        _logger.info("out:SLBThingTemplate.initializeThing()");
    @Override
    public void processStartNotification() {
        super.processStartNotification();
        try {
            _logger.info("in:SLBThingTemplate.processStartNotification()");
        } catch (Exception e) {
            _logger.error(e.getMessage());
        _logger.info("out:SLBThingTemplate.processStartNotification()");
