Fetch "Link" field in a Menu Definition using Javascript
  • January 8, 2018
  • 0 replies
  • 1240 views
I have a custom menu.  When you select the type as Mashup, you get to specify the "Link" which is another mashup.  I cannot seem to access this field via the Javascript API, since the datashape (PTC.Asset.MenuEntry) associated with getting the menu does not contain this field.  Does anyone know how to do this?
