Jan 13, 2025 2:30 PM UTC
Fetching PVZ with ThingWorx Flow
I'm working on a project that requires the fetching of pvz from thingworx flow. I used the following actions to do so: get structure to fetch BOM, a loop to iterate on each element of the array fetched with the aformentioned action and a get content to fetch pvz. The issue is that the fetched pvz are almost empty. Is there another way to fetch pvz?
Thanks in advance
slangleyAnswer
Support
Jan 15, 2025 8:48 PM UTC
Hi @FC_12202090.
Take a look at this article.  If it doesn't help, please provide more details of your configuration.
--Sharon
Jan 15, 2025 12:09 AM UTC
Similar discussion - "PVZ for positioning assembly": https://community.ptc.com/t5/ThingWorx-Developers/PVZ-for-positioning-assembly/td-p/778825
slangleyCommunity ManagerAnswer
Support
Hi @FC_12202090.
--Sharon
Jan 28, 2025 8:02 AM UTC
Hi @slangley , I will try to apply what said in this article and let you know if there are any issues.
Support
Jan 27, 2025 7:35 PM UTC
Hi @FC_12202090
If you feel your question has been answered, please mark the appropriate response as the Accepted solution for the benefit of others with the same question.  If you still have questions, please let us know.
--Sharon
