File transfer from server thing to remote thing in agent is not working
  • September 11, 2015
  • 3 replies
  • 1746 views
I am transferring a zip file from server to remotethingwithfiletransfer in agent(EdgeSDK .net code ). But i the file is not copied to agent's virtual directory and i am getting  the below error "The given key was not present in the dictionary." in the result of calling copy service in thingworx server. Let me know if you could help me in resolving the same.
Thanks.
    Check read/write permissions of your Repositories. It should be creating some sort of Temp subfolder I believe, might be failing that.
    Hi Now we are getting different error. The file is transferred from server repository to SDK solutions virtual directory. The file is transferred but in the result infotable of copy service
    1. Code is 500 instead of 200
    2. State is ERROR instead of VALIDATED
    3. Message is Unable To Convert From InfoTable to INFOTABLE instead of file transfer complete
    4. isComplete is flase instead of true.
    We had tried the same code with two different sdks. The code provided below is put into the service of a thing in server.
    var params = {
                    async: false /* BOOLEAN */,
                    sourceRepo: "Tierra" /* STRING */,
                    targetRepo: "Prescription" /* STRING */,
                    targetFile: FileName /* STRING */,
                    targetPath: "In" /* STRING */,
                    sourceFile: FileName /* STRING */,
                    sourcePath: "/" /* STRING */,
                    timeout: 150000 /* INTEGER */
    ServerDirectory is a thing based on FileRepository. SDKCommonThing is a thing on the Dot net EDGE SDK side. We are not sure what causes Unable To Convert From InfoTable to INFOTABLE.
    Let me know if you could provide any input on the same.
    Given Result Table Below:
    targetChecksum
    code
    isAsync
    maxSize
    sourceFile
    startPosition
    duration
    isRestartEnabled
    targetFile
    startTime
    state
    sourcePath
    blockCount
    sourceRepository
    bytesTransferred
    targetPath
    sourceChecksum
    message
    transferId
    blockSize
    size
    endTime
    targetRepository
    user
    isComplete
    3fa8a947d6ce15fa97e1bd7cf860112f
    500
    false
    100000000
    Prescription001.zip
    0
    835
    true
    Prescription001.zip
    2015-09-22 12:03:43
    ERROR
    /Outgoing/Prescription001.zip
    12
    Tierra
    771137
    In/Incoming/Prescription001.zip
    d3f0a7e5-3724-43cd-9954-b42c958e663e
    65536
    771137
    2015-09-22 12:03:44
    Prescription
    Administrator
    false
    If this is the standard messages that the File transfer should be generating, then it looks like it may be a bug. Please submit this at support.ptc.com
