Google Map Problem
  • May 22, 2017
  • 7 replies
  • 2618 views
Hi All,
   I get my data from database, and start a new column LOCATION from other two columns, latitude and longitude.
It looks like two digits from longitude and latitude are missing in LOCATION.
I attached the data to the google map widget.
The google map shows nothing. Something is wrong here.
Please advise. Thank you!
Hi Tiantian Guo​,
Just to confirm; are you following this youtube tutorial: Thingworx Fundamentals 101 -- How To Use a Google Map Widget - YouTube
tguo1-VisitorAuthor
Yes. I am following the procedure.
Actually I have done this successfully before. I enter the location manually in the service in javascript. Then the location data can be attached to the google map.
But this time, I obtain the data from the database. The problem happen.
Hi Tiantian Guo​,
Please share the export of your mashup here.
