Google Maps Widget bug using Master
  • July 11, 2016
  • 4 replies
  • 2077 views
Hi All,
I believe I have found a bug with the Google Maps widget but didn't want to log a case with PTC in case somebody had a solution?
It appears when using a Google Maps widget inside a contained mashup (in my case the contained mashup of a Master) the widget appears to be distorted as below:
Note: The above example uses geofencing which currently only has ONE region created. I am also using ThingWorx 7.1
The widget content should fill the whole space but instead just a square in the corner.
Best answer by Aanjan
Ashley, are you using any tabs or a popup as well? I tried reproducing on my end with the map on a Contained Mashup, and it rendered correctly. What browser are you using? I tried mine on Firefox; so if you didn't try it on Firefox, can you possibly give it a shot there?
What kind of display settings are being used on this mashup (with the Google Maps widget)? Is a size specified? Is it static or responsive?
I do not seem to see this issue with the Maps widget, but I am not using any kind of geofencing on mine, so that may be directly related.
ashleyg1-VisitorAuthor
Hi Tori,
It is responsive however it appears launching in Firefox works but Chrome does not, rather inconvenient.
Ashley
Aanjan5-Regular MemberAnswer
Hi Aanjan,
It appears that launching the Mashup on Firefox fixes this problem, although it isn't idea, any idea why this is the case? Is there anything I can do to get it to work in Chrome?
Ashley
