Grid won't be editable
  • April 26, 2016
  • 8 replies
  • 4071 views
Following procedure does not work...
1) Put the grid on the mashup.
2) Set "IsEditable" property true.
3) Bound "All Data" from "XXXThingTemplate#GetImplementingThingsWithData".
4) Open the Widget Config window of the grid.
5) Check "Editable" for each property.
6) Save & View Mashup.
All of the columns are still Read-Only.
(, while Property Value widget works well..)
Are there any thing yet to be done?
Version 6.5.8 b-4
Best answer by Aanjan
Matthias, can you try using a Number instead of Integer? It looks like don't support those basetypes; I'll file an enhancement Jira to support all basetypes in a future release.
22-Sapphire I
April 26, 2016
You are saying that the Grid is not showing the cells as Editable, or you can't do an Edit and Save the changes?
???-311-VisitorAuthor
I mean the grid is not showing the cells as Editable.
Completely the same appearance as the non-editable grid.
Do you have ShowAllColumns checked? Can you try displaying only the columns you've set as editable?
